주요 콘텐츠로 건너뛰기
Samsung에서 제조한 Samsung Galaxy Note 5는 (Note5로 불림) 스타일러스를 탑재한 phablet/패블릿 스타일 휴대폰입니다, 2015년 8월 출시.
271 질문 전체 보기
Why is my screen blank
I am an iphone repair guy and have fixed hundreds of iphones. Recently started advertising android repair. Have a note 5 with a blank screen but the small light at the top left comes on blue. when i charge it, it shows green for full charge. anything i can do to get it to turn back on or is the lcd dead? i know barely anything about androids compare to iphones so i don't know the tricks to possibly fix things like this
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
Check the logic board for water damage and clean them with stuff like 99% isophryl alcohol if needed.
Make sure lcd cable is plugged into board well.
Other than that it's most likely the LCD. Have you carefully inspected the screen for cracks?
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
the screen is cracked a bit on the bottom could that be the problem?
If it's on the glass then it should still display. If there is a crack on the black LCD side then the screen needs to be replaced.
댓글 달기
Look in different angles at the screen to see if there are inner cracks on the surface of the LCD (not the outer glass). Samsung screens are more fragile than iPhone screens, if the outer glass is shuttered, it can be replaced or at least you should still be able to use the device. It's most likely a broken LCD and you need to replace the whole screen assembly. Double check the screen connector when you disassemble the device, if it somehow got unplugged, but that's less likely.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Nick Gibboni 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 619
