주요 콘텐츠로 건너뛰기
New Contol board, new problem!
Our Frigidaire electric dryer (model GLEQ2152EE1) started randomly beeping. Error code diagnosis said we needed a new control board. New board installed and the beeping stopped, however, now the numbers for timed drying are nowhere near what shows on the digital display. i.e., when when you turn the dial to 75 min., 30 shows up on the digital display. I reported it to the place where I bought the part and they sent me another control board. Installed it today and the same problem. Is it possible we got TWO defective control boards or is it something else now?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
@hermine exactly which error code did you get?
E93 was the original error code
댓글 달기
답변 2개
선택된 해법
it probally means it might need a new lcd driver as well as i can tell.
your trusty tech source,
bacon
이 답변이 도움이 되었나요?
점수 -1
댓글 3개:
bacon, Thanks for the suggestion. Have ordered the part and will let you know if that solves the problem.
Actually, installing this part did not solve the problem. :(
then you may need to do some programming for the display output.
bacon
댓글 달기
The control is probably 180 degrees off. You will have to find a way to turn it with the knob out since it is keyed. I have had to do that before with my own dryer.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Holly McPheeters 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 131
