주요 콘텐츠로 건너뛰기
모델 A1237 또는 A1304 / 1.6, 1.8, 1.86, 또는 2.13 GHz Core 2 Duo 프로세서
312 질문 전체 보기
white screen problem on boot
I own an apple macbook air model number a1237 that has nothing but a blank white screen on boot after the startup sound. I have tried two different screens and lvds cables. it works great on an external monitor thought. any help would be greatly appreciated.
Thanks,
Cody
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 4개
선택된 답변
Hook it up to an external monitor to check the GPU and logic board.
해당 답변은 도움이 되었습니까?
점수 5
댓글 4개:
ill have to test that when i get done with class today. if it were to work on an external monitor, any thoughts on what could be wrong with it?
Please list the last three letters of your serial number. Thanks
y51....and it does work with an external monitor my previous post that said it didnt was incorrect
댓글 달기
The LVDS is causing the issue and needs to be replaced by a professional certified Apple Technician with appropriate device.
Update
1- The connector between the logic-board and the CABLE that comes from display is loose.
2- Other possibilities?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
north bridge(gmch) error-fauller
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
이 답변은 원래 다른 질문의 답변입니다.
I had this same issue. White screen, chime, responded to light sensor. Hooked to external monitor, would get video there. But I could only get a white screen on the internal monitor. I swapped the logic board with a known good logic board and this fixed the issue. So I'm going to say it's a logic board issue, strange as it is, or a logic board to LVDS connector issue (all I did was remove this, the HDD connector, data/usb connector, airport card connector, magsafe port, iSight connector(?), and top case connector, to swap the logic board). I had a !@#$ of a time finding any info, so I hope this helps some people out there. I'm going to investigate and see if I can find any further answer to this.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Cody 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 7
전체 시간: 5,438
