주요 콘텐츠로 건너뛰기
Apple 주문 번호 MC007LL/A / 27" 2560x1440 픽셀 화면
78 질문 전체 보기
Fan runs on full power without regulation
Hi Guys,
when i start my monitor, the fan start to running -in my opinion- with the full power.
Okay that would be normal in the beginning BUT it dont stop ...
The fan is so loud and underneath the display there is a lot of air output on the LEFT side.
Actually i tought when i set the brightness to MINIMUM and have only my desktop open on the cinema, it will regulate the Fanspeed to a minimun so you cant hear anything of them ... but it still stays on the fan RPM level...
I dont know what to do ? Maybe is there any temperatursensor broken ??
The Monitor ist connected on an iMac 5k Late 2014.
And yes i have the usb also connected with the iMac.
Please help me :(
Thanks
Manuel
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
From what you have described it sounds like a temperature sensor is either having issues with:
1. Reading the right temperature.
2. Has been knocked out of place or tampered with.
3. Your Monitor is actually heating up to a temperature in which the computer believes it should turn that fan on high.
If you really think that it is an issue with the temperature sensor, and not your computer actually over heating. I recommend the program Macs Fan Control (http://www.crystalidea.com/macs-fan-cont...).
This program will allow you to adjust the RPM of your fans and also view in Celsius or Fahrenheit what temperature the components in your computer are at.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Manuel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 195
