주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2008 netbook; Model ZG5 AOA150-1691; 8.5" screen; 1.6 GHz N270 Intel Atom Processor
Dead Acer Aspire ZG5?
Hey guys.. I have an Acer Aspire ZG5, that I got a year ago, running Windows 7. It worked perfectly, like a charm. But I forgot about it, and and put it in a locker. I opened it up recently, and found the computer. I picked the charger, plugged it into the wall and on the machine. I pressed the power button, but the battery light turned on, and faintly turned off. Sometimes, all of the lights turn on, and suddenly turn off. I tried to do a hard reset (no battery, just charger). Nothing. I tried to do the reverse (only battery). No response. I don't know what to do, is it because of the dust that maybe inside it?
I hope that I get it working fast...
Greetings,
~Gum
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 6개
Hi Try letting the charger charge the battery for 3-4 hours before attempting to switch it on and see what happens. A dead flat battery need to be given a chance to revive.
I will try. It needs to rest a bit.
@jayeff
most laptops can run with 0 battery or even no battery, they can get power directly from the adapter.
Try taking out the battery completely and then try to turn it on again
Hi @ethanchow00
Thanks for that.
@ethanchow00
I tried, no success.
댓글 1개 더보기
댓글 달기
답변 1개
선택된 해법
Gum , Try a reset, remove battery and charger/power cord. Hold in the power button for 30 seconds to reset the computer. Reinstall the battery, plug power adapter and try. This works for lap tops with your issue a lot of the time.
I hope this helped you out, if so let me know by pressing the helpful button. Check out
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
I was hoping you were my angel, but it didn't work.. I still think it might be something (dust, i mean) inside it.
Sorry it did not work for you. Try a google search (Acer Aspire ZG5 not turning on) quite a bit of info. out there and things you can try, some say reseat or change the Ram, disassemble and look for a pinched ribbon cable, some say it is a Bios problem and needs recovered. I hope this may help, good luck with your laptop.
https://www.youtube.com/watch?v=gkP5KiCS...
http://ccm.net/forum/affich-95127-acer-a...
http://laptoprepairblog.com/acer-aspire-...
This worked for me on day 7 covid lockdown in South Africa
댓글 달기
답변을 추가하세요
Gum Skyloard 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 16
전체 시간: 1,431
