주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mitsubishi Lancer 8세대 모델.
ignition switch wiring diagram color codes
what are the wiring color codes of ignition switch
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 3개
선택된 해법
Peter, You can find your wiring schematics at the sight attached and download free.
http://www.revbase.com/BBBMotor/Wd
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Peter Celdran, not quite sure what you are looking for but start with this
이미지
You definitely have 3B- Yellow, 2B- White and 2L-Black. If you post some images of what you are looking at, we might narrow it down. Use this guide for that.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
이미지
this is the harness I just need to know which one is the battery wires and which one is the ignition wires
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
@bonnie88229 looks like Black/Yellow and Black/White for the ignition. White should be battery but we need to know the exact year, model and engine size to make sure. Use a test light or meter on each wire. You should be able to get the battery + which should have power at all times.
anyone have a wire diagram for a 2004 Mitsubishi lancer ralliart manual 2.4l? especially the ignition diagram dealing with no spark but I'm getting gas so I wanna make sure the wires are ok
댓글 달기
답변을 추가하세요
Peter Celdran 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 18
지난 30일: 98
전체 시간: 13,183
