주요 콘텐츠로 건너뛰기
The BlackBerry Z10 is a touchscreen-based smartphone developed by BlackBerry, previously known as RIM.
73 질문 전체 보기
I have www-bberror-com-bb10-0015 on my screen (model STL100)
i cant locate phone on pc and cant do anything with phone because of error message please help im such a novice.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 46
댓글 5개
www.bberror.com/bb10-0015
fredreck
kalumba
Download this program, install it and hook your Blackberry to the computer and allow it to upload the OS back to the phone itself. https://us.blackberry.com/software/deskt...
Help me. My phone have a bberror bb10-0015.. I can't fixed. Because I don't have PC😭😭😭😭
How could I downloaded to open
Or
So that My phone can operate
댓글 달기
답변 7개
선택된 답변
This is the explanation
http://btsc.webapps.blackberry.com/btsc/......
And this is the solution
해당 답변은 도움이 되었습니까?
점수 19
댓글 2개:
It keeps going around in loops. It does not resolve my issue. When I visit Link, I get a "Software Update encountered and error" - check your network connection . But guess what, I have full internet access. I do not have any limitation.
Both links work for me in safari.
댓글 달기
The error you mentioned above can often occur due to various reasons but one solution is to remove the current OS and by auto loading the OS again on the device.
Download the autoloader for your device from here
http://developer.blackberry.com/
And follow the steps below:-
1-turn off your device
2-connect your device to pc
The downloaded autoloader must be present on your pc and installed or unzipped
3-now run the autoloader and turn on your device.
Once autoloader recognizes your device it will start loading OS on it again after its finished green LED will light up.
After its finished your phone will restart give it sometime and all done.
I hope this helps! Good luck!
해당 답변은 도움이 되었습니까?
점수 4
댓글 2개:
I HV a problem with my phone blackberry z3 it say www.bberror.com/bb10-0015
Pareho po tayo
댓글 달기
Am having a problem of error message when I start it and have downloaded auto loader but it says error message when the prompt has stated what should I do?
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I connected my device to the PC and downloaded my software but still not working..please
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
This error comes when the mobile battery is taken out from the mobile without making mobile switch off
So its a normal error and to solve this error have to flash the mobile but it will loose all mobile data from the mobile and will be the like new one after flash
Here is software pb tool to solve this issue
https://www.waveclues.com/blackberry-z10...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
blackberry dev alpha c how to download softwear
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
How do I fix my blackberry says bberror0015 and my phone is flash green when plugged in but when unplug it has redlight
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
probinson1970 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 7
7일 전: 35
30일 전: 134
전체 시간: 27,513
