주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
Black camera after display repair.
Hi, i just dropped my 64gb iPhone 6s and broke screen + lcd, when i repaired it my camera started to show a black screen and i'm unable to switch between front/rear cameras and use flash.
I bought a new original apple camera and changed with the old one, it didn't worked,
could the problem be the power management ic of the camera? If the anwer is yes how can i repair it?
Is still the u2301 from iPhone 6?
Thank you in advance for the answers, have a good day.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 5개
Was the battery unplugged during the whole process of the repair? If not then you may have shorted the camera ic chip on accident when removing / plugging in the screen ribbon cables.
it was not, i forgot sadly... this is the reason that make me guess is the ic, do you know the exact component name/location on the board? since i'm not able to find it on the net...
Some leads? i have no clue how to repair this :(
I have no info on where it is on the 6s unfortunately.
I will try it hoping is the u2301 even in the 6S model.
U2301 is for the 6 i guess.
댓글 달기
답변 2개
가장 유용한 답변
Hello Federico Vaccaro,
  • Inspect whether any component missing the near FPC connector
* Check the IC U2301 output & it should be 2.8V. if it is OK suggesting you to clean the FPC connector on logic board and carefully resolder it (micro soldering skills required)
Hope this answer will help you to fix the camera issue on your iphone. Good luck!
해당 답변은 도움이 되었습니까?
점수 1
댓글 3개:
Federico. Did you solve the problem. Because I have the same issue.
i do too. where do i get replacement IC's for this?
댓글 달기
Hello friends,
I'm also having the same problem on an iphone 6s, has anyone figured out if it's the same as the 6th IC that caused the problem?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Federico Vaccaro 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 4
전체 시간: 368
