주요 콘텐츠로 건너뛰기
모델 A1419 / EMC 2806 / Late 2014 또는 Mid 2015. 3.3 또는 3.5 GHz Core i5 또는 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 또는 3.5 GHz Core i5 또는 4.0 GHz Core i7 (iMac17,1) 모두 Retina 5K 화면 장착
573 질문 전체 보기
Confused on which to use?
Do the replacement screen for: Apple iMac 27-inch LCD LM270WQ1-SDF1 PN: 661-7169 2012 2013 come with two connecting ribbon or one!
A replacement from China says it only one ribbon! Not sure if to order it?
I appreciate your reply since you all have the great experience with everything!
Thank you
Carlos
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
Can you give us the exact model of your system. If you don't know plug in the S/N here: EveryMac - Lookup You'll find the S/N on the bottom of your systems foot stand. Once you know the model paste in the systems URL link so we know as well.
댓글 달기
답변 3개
이 답변은 원래 다른 질문의 답변입니다.
OK, thanks, that is what I have been seeing.
I suppose one has to take the Display Port Cable from the old Screen and swap it to the new one!
I was afraid in ordering because there are two ribbons to be disconnected but I guess this port ribbon is disconnected at both ends and is swap-able!
Thank you Jamie, that was a quick response!
Cheers
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Quick but incorrect!
댓글 달기
OK. FYI: When you buy the Screen assembly, it only comes with one connector cable, the one shown in this correct model screen assembly on the picture Jamie uploaded. The Ribbon cable to the new Screen Display port lcd cable, 98% of the time does not come with the new Screen you order and must be purchased separately only IF, your existing one is damaged. Ask the seller if they send it with the replacement screen so you are aware if to order one!
One more detail! You will need new mounting adhesive tape to reassemble your new Screen! You must buy a new set or ask the seller if they send an adhesive kit with the screen they are selling you!
This will save you time after your get the screen, so you don't have to wait again for just the Adhesive to arrive, to complete your installation!
If the existing Display port lcd cable on your existing screen is OK, you can just swap the old screen Display port lcd cable to the new Screen Assembly!
See This interchangeable ribbon Display port lcd cable here below!
The 2nd connector, the Display Ribbon!
Hope this saves reader's time/delays, money and troubles!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
There is just one ribbon as you can see in this full assembly unit below
Good luck with your repair!
해당 답변은 도움이 되었습니까?
점수 -1
댓글 3개:
It is alway good to post links to your references. We have no way of knowing where that one came from, or if it is even the correct display.
Look carefully!
The image of the display unit you have in your answer has two connections. The black cable on the left is the backlight power lines not a ribbon cable. The ribbon cable is missing in this image, it connects to the top midpoint connector.
Thansk Dan for the Clarification!
i got it!
The Ribbon cable is the one that comes off both ends from the old screen and placed in the new screen!
Do I have this right now? About the reuse of the Ribbon cable one!
댓글 달기
귀하의 답변을 추가하세요
Carlos 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 121
