주요 콘텐츠로 건너뛰기
모델 A1419 / EMC 2806 / Late 2014 또는 Mid 2015. 3.3 또는 3.5 GHz Core i5 또는 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 또는 3.5 GHz Core i5 또는 4.0 GHz Core i7 (iMac17,1) 모두 Retina 5K 화면 장착
iMac 27 Late 2015 - Black Screen After HDD Replacement
Hi all,
I've replaced the hard drive and thought I had no problems until I tested the unit before reassembly, essentially I get the start up sound , fan and hdd whirling but a black screen. There are four indicator lights but only three are on. This is my first Mac upgrade so criticism is okay. Thanks.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 달기
답변 2개
선택된 해법
Since this machine was under warranty, why are you into it in the first place?
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Had to replace hard drive.
Since this machine was under warranty, why are you replacing the hard drive and voiding your warranty?
댓글 달기
Try reseating the display connector, if it doesn't work, you may have damaged something in the process as you said that it is your first time, and this is a hard repair. Try plugging it into an external monitor if you have one. If you can't get it up and running try to put everything back together as original as you can and bring it into an Apple store and see what they can do as it must still be under warranty.
이 답변이 도움이 되었나요?
점수 0
댓글 5개:
I don't see any ports for an external monitor, just USB and Ethernet.
it should have a thunderbolt port. It is a little square-almost trapezoid that has a lightning bolt near it.
Okay, I see the thunderbolt port, now I have to get a cable that goes to HDMI. Question: what do you suggest I do if there is output to the external monitor?
If you have another Monitor you can connect with thunderbolt - mini Displaybort to VGA or DVI Adapter. You can order them from Apple online store
try to restore it to factory conditions (minus the problem) and take it to an apple store of an ASP and play dumb.
댓글 달기
답변을 추가하세요
StaceyK 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 34
전체 시간: 2,022
