주요 콘텐츠로 건너뛰기
모델 A1138 / 1440x960 스크린 해상도
85 질문 전체 보기
Works fine until a battery is connected, then shuts off
Hi All! I've got an A1138 PowerBook that works fine on AC power with no battery attached, but when I connect a known-good battery (I've tried several known-good batteries), the machine immediately shuts off. The AC adapter light, which glows bright green without the battery in, goes out completely and erratically flickers amber when you connect a battery. The machine won't power on with a battery in except occasionally, and quickly goes off again. Again, this all happens when a battery is connected, and without a battery, everything's fine. My first guess was the battery connector, but I replaced that with no change. Next up was the DC-in, and I tried 3 I had sitting around, although I think they all may be flaky to some degree, so I'm not confident I've properly ruled out the DC-in. I've got a good DC-in on the way, but I'm not sure that's the problem...this seems more like a short, or an electrical issue. Any ideas? I know it's not the RAM, AC adapter, resets, etc. Thanks!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 1개
Got the replacement DC-in, and no luck. It behaves exactly like the other, which is perfectly, until you add a battery, and then the machine shuts off, and the AC light glows off and on amber.
댓글 달기
답변 1개
선택된 답변
OK, this is a shot in the dark. Disconnect the battery connector cable from the logic board and insert a battery to see if it's physical.
해당 답변은 도움이 되었습니까?
점수 4
댓글 2개:
Without the battery connector nothing happened. Good idea though!
Sounds like a logic board to me. You guys have such interesting problems. + to both.
댓글 달기
귀하의 답변을 추가하세요
rdklinc 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 5
전체 시간: 2,190
