이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
Hi, I assume it happens when you print from a PC, is this correct? Try copying (or scanning) a page of text using the printer's control panel. Does it happen then as well? When you say 'certain text' can you give more detail? is it colour for instance or always the same area of the paper etc?
jayeff 의
