주요 콘텐츠로 건너뛰기
7" multimedia tablet by Barnes & Noble, released in November of 2011. Fixes are easy and require simple prying tools and screwdrivers.
Nook shuts off when SD is inserted
NOOK model BNRV200. I just replaced the battery, nook turns on but when I insert the SD card it shuts down and will not power back on. I can only get it to turn back on when the SD card is removed. All functions work when SD is not inserted.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Check the SD slot to make sure no contacts are crossed or there is nothing jammed in there that would short out the contacts when SD is inserted. Also make sure that this SD card is of the correct size for this tablet and has been formatted correctly. It may need reformatting or replacing. Also check the work you did on the replacing of the battery. Make sure nothing is bent shorting out or broken.
댓글 달기
답변 1개
@zinny sound slike either your SD card or the SD card reader is shortenibng out when you insert the card. Try a different card, should it still shorten out open your Nook up and take a look at the card reader. Also, double check your work since this started after you repalced the battery. Make sure everything is properly connected and that nothing got bend or broke.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Zinny 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 3
전체 시간: 131
