주요 콘텐츠로 건너뛰기
A rotary tool by Dremel with different speed settings and attachment options.
6 질문 전체 보기
No Power coming from tool
I was cutting a sheet of paneling and the tool stopped and the 3 battery indicating light on the tool was flashing 1 at a time so i plugged in the battery and set to charge and after charged the same 3 lights on the tool were still blinking and still no power to the tool
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 6개
Hi Kevin,
It's hard to say without seeing the tool but from what I can tell from your post is that you need a new battery or new charger.
When you put the battery on the charger it should blink. When the battery is fully charged the lights should be solid green. If the battery has had enough time to charge it should be good to go. From my research this seems like a common problem with that model.
Not sure how long you've had this tool but it does come with a 2 year warranty.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
3 "flashing" lights means the battery is to hot for use.
Update (01/05/2018)
If you have a defective unit you can contact dremel and they may send you a replacement.
1-800-437-3635
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
The unit has "flashing lights" when the unit is cold. I can't get the unit to even come on to get hot. But thanks for your comment
댓글 달기
Hi Kevin,
From my research I can say that you probably have a faulty battery or charger.
The green lights blink when the battery needs charged. If the batter was given enough time to charge the lights will be solid green.
I know your tool should come with a 2 year warranty. I would check into that if it's within the time frame.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hi Kevin,
This is not the battery.
I have the same problem with a 8200. Bought a 8220 (latest model) and its new battery causes the same 3 flashing lights in the 8200 but the old 8200 battery works fine in the 8220.
Therefore the tool itself is bad.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Same thing still happens with the 8240. Bosch needs to fire that engineer.
댓글 달기
My ginour mini rotary tool stopped working and 3 red lights stay on can I fix it myself?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have the sam problem but if you slam the battery in quickly it will go on and work you can control speed but the on off switch doesn't work unfortunately. You have to remove battery again when you're done using it to turn off. I lower speed to lowest setting then remove battery to turn off. Hope this helps get some more use
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Kevin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 6
7일 전: 22
30일 전: 94
전체 시간: 4,408
