Looking for WiFi Antenna Part?
I note that iPad 2 Bluetooth/Wi-Fi Antenna says its not for the EMC 2560 model, but is there a suitable antenna available somewhere?
좋은 질문 입니까?
좋은 질문 입니까?
I think this is it: http://www.powerbookmedic.com/Wireless-3...
해당 답변은 도움이 되었습니까?
Sorry but that one says its the 3G antenna not the Wi-Fi one ?
I've replaced hundreds of iPad 2 antennas and never worried about which model it was. The connection is the same on them all and the mounting is the same. There are no electronics to deal with, its all analog.
You should be good to go. I do remember seeing a couple iPad 2.5s with weird antennas. If you could post a pic of yours, I could tell you 100%
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 84
댓글 1개
So what's the verdict, does this one work? The post labeled as the answer is indeed AN answer but hardly a solution and leaves the issue annoyingly unresolved and in an ambiguous way. I indeed have an iPad EMC 2560 that I'm about to replace the logic board in and was going to grab the cheap & especially fragile parts for the numerous reasons to do so and not that I won't be able to complete my repair without it but now I'm just curious what is so different or incompatible about the EMC 2560's and what's the solution or reccomendation if one should happen to require a replacement antenna for this model. Thanks in advance.
Nick Novia 의
