주요 콘텐츠로 건너뛰기
Released in 1996 by Nintendo, second device in the Game Boy line
15 질문 전체 보기
Gameboy Pocket Inductor Replacement
I have an old Gameboy Pocket unit that was dropped and does not power on. After disassembly, the only damaged part appears to be a polymer encased inductor mounted on the small sub-board in the bottom corner of the PCB. The polymer canister that holds the inductor coil is breached and the wire has become partially unraveled. The canister is labeled as follows:
066
Yy
I've done some looking around online, and I haven't been able to find anything about this particular part or how to find a replacement. The only option I've been able to come up with is scavenging an entire sub-board from another unit. Any help is appreciated.
Update (10/06/2016)
Hope this helps.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
Hi,
Could you please send a picture of the damage component ?
JM
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Let me know if you want any other images. If needed, I can de-solder the sub-board to see it in more detail.
댓글 달기
귀하의 답변을 추가하세요
Sakurazaki Sakai 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 5
전체 시간: 953
