주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Game Boy Pocket은 1996년 Nintendo에서 출시되었습니다. Game Boy 라인업의 두 번째 기기입니다.
Gameboy Pocket Inductor Replacement
I have an old Gameboy Pocket unit that was dropped and does not power on. After disassembly, the only damaged part appears to be a polymer encased inductor mounted on the small sub-board in the bottom corner of the PCB. The polymer canister that holds the inductor coil is breached and the wire has become partially unraveled. The canister is labeled as follows:
066
Yy
I've done some looking around online, and I haven't been able to find anything about this particular part or how to find a replacement. The only option I've been able to come up with is scavenging an entire sub-board from another unit. Any help is appreciated.
Update (10/06/2016)
이미지
이미지
이미지
이미지
이미지
Hope this helps.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
Hi,
Could you please send a picture of the damage component ?
JM
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Let me know if you want any other images. If needed, I can de-solder the sub-board to see it in more detail.
의 공유
댓글 달기
답변을 추가하세요
Sakurazaki Sakai 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 19
전체 시간: 1,385
