주요 콘텐츠로 건너뛰기
첫 번째 iPhone 모델, Model A1203은 4, 8, 또는 16GB 용량과 알루미늄 뒷면을 가지고 있습니다. 수리를 하려면 상당한 양의 비집기와 납땜을 요구할 수 있습니다.
224 질문 전체 보기
iPhone 2g says it has no wifi, how do I fix that?
The person who I bought it from said he replaced the back cover and motherboard and everything was perfect until like a few days before he sold it, he said that the wi-fi just stopped working.
Anything I can do to repair it ?
*Since the cover is not from the original phone, and neither is the motherboard, the model listed to the right might not be accurate, because the motherboard is a 4gig and the cover says 8gig on it.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 3개
가장 유용한 답변
If the logicboard has been replaced, it sounds more like the wi-fi antenna plug has not been properly seated.
For the wi-fi to operate properly, the cable must be 100% screened off.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Usually, the white antenna cable on the left side needs a replace.
It could remain pinched when closing the shell and no signal is received.
Happened to me when I did a battery replacement on a 2G iPhone. Replacing the cable the fault was fixed.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Where can I buy a new one and follow a video to replace it?
댓글 달기
rehot ur wifi module thats all
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Mehraan Sayed 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 4,425
