주요 콘텐츠로 건너뛰기
The Asus Zenbook UX301LA is an Ultrabook with a 13.3-inch IPS display. It was released in November 2013 as a part of Intel's Ultrabook line.
16 질문 전체 보기
Cost of screen replacement
What would it cost to replace a broken screen on Asus Zenbook UX301LA?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 3개
선택된 답변
Hi,
I do not know how much the repair would cost, but here is a link to an Asus supplier that gives the cost of the various types of LCD screens available for your model laptop. Scroll down and click on LCD Panel. The part number for your model is to be found on the back of the LCD panel, i.e you have to open it up to find out.
If you Google just the part number of the particular screen you may find other suppliers with better prices.
http://www.asusparts.eu/en/partfinder/As...
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
Had to replace screen on my ux301la recently. I found replacement screen assembly on eBay for around $160 and I replaced it myself. 15min job. The rear cover has razor sharp edges from inside so be cautious when removing it.
해당 답변은 도움이 되었습니까?
점수 2
댓글 5개:
Would you mind helping me work out how to replace the screen, do i need to detach it from the mainfraim or can it wihout? Any help would be appreciated. Thanks.
Hah cut myself too.
Hi team, i need to replace my LCD cable. How on earth do you get to the end that attaches to the LCD. where do i take apart the LCD, i cant get past the hinges
@drpotatoman good day sir. How do i replace the LCD cable for my Ux301LA. i can detach from the motherboard. but not sure how to get it out of those hinges. also do i need to dissamble the glass ASUS lcd>?
Hi @Greg Chandran, this was a long time ago, so I don't remember much. But I do remember that I got a whole new LCD screen assembly from eBay and if my memory serves me correctly, that came with the cable, so I didn't replace it individually. All worked perfectly after repair.
댓글 달기
Here you find also the needed parts:
https://www.ipc-computer.de/notebook-ers...
or
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Bjarne Borg 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 9
30일 전: 47
전체 시간: 15,670
