주요 콘텐츠로 건너뛰기
The Acer Iconia W3-810 is a Windows tablet with an 8.1” HD screen and an Intel Atom Dual Core Z2760 processor.
Why can’t my tablet connect to WIFI?
I can not get my tablet to connect to the WIFI
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 1개
It not the network as i have reset it and all other devices have picked up the network
댓글 달기
답변 2개
가장 유용한 답변
Hi @Michael Emery,
Can you access the network when the tablet is right next to the router?
If so try disabling the tablet’s WiFi’s minimum power consumption setting. Go to Device Manager > Network Adapters > right click Broadcom Wireless > Properties > Advanced > minimum power consumption and see if that helps. (not quite sure if it is called minimum power or something similar)
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Make sure the WIFI is enabled. If this does not work perform a hard reset. If the problem still persists check your router or modem to see that they are properly connected.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Kyle Coker 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 9
전체 시간: 685
