주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
3MB 공유 L3 캐시 2.5 GHz 듀얼-코어 Intel Core i5 프로세서 (Turbo Boost 최대 3.1 GHz).
Backlight not working on display
The backlight to my macbook display isn't lighting up. I know I get video, because if I hold up a flashlight against the Apple logo on the back of the display I can see my login screen in the front. I was thinking it could be the backlight fuse, but I dont know where its located on the logic board?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Hello Jstervil,
It may very well be the backlight filter. There is not a user replaceable "Fuse". The backlight filter is a soldered on SMD "surface mounted device" and will require microsoldering skills nd a lot of specialized equipment to repair. This, sadly, is not a DIY repair. Call around a few shops in your area and see who would be willing to take on that job. Get several quotes though as they could range significantly.
Hope that helps,
Holger
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Thanks for the response Holger,
Would you happen to know and show me where the backlight filter is located on the logic board? Also, I'm guessing replacing the display will not solve the problem, right or wrong?
You are correct in that replacing the display will not correct the problem. I'm out of town at the moment so I don't have access to the board schematics.
댓글 달기
답변을 추가하세요
Jstervil 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 10
전체 시간: 186
