주요 콘텐츠로 건너뛰기
모델 A1502 / 4MB 공유 L3 캐시 2.6 GHz (Turbo Boost 최대 3.1 GHz) 또는 2.8 GHz (Turbo Boost 최대 3.3 GHz) 듀얼-코어 Intel Core i7 프로세서.
494 질문 전체 보기
Can Retina displays be repaired?
See image below. The display on a 13" Retina Macbook Pro from 2014 is showing lines. I know the issue is with the display itself. My question is, can this unit be repaired? Could the LVDS cable be reseated internally, for example? Is it even possible to open a Retina display, or does everyone just replace the entire display assembly?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Retina systems use iDP signaling not LVDS. Unlike LVDS iDP is an all or nothing signaling similar to your digital TV over the air works. You might see some checker boarding if the cable is making and breaking contact.
댓글 달기
답변 2개
선택된 답변
Oh, you can open it, it's just getting it to work afterward.
I'd love to see a really good repair guide along with reasonably priced parts.
But as of this time, I am still having to replace the whole unit.
I'd love to hear from someone who has done it successfully.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Yep, just easier replacing the complete lid assembly
댓글 달기
It is NOT possible to separate a retina screen, any attempt simply breaks it.
Also this is clearly a fractured LCD, there is no point messing with the cable, just replace the lid assembly.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Colin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 3
전체 시간: 123
