주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung NX Mini는 2014년 3월에 출시된 미러리스 디지털 카메라입니다.
Zoom lens won't unlock
I have never drop this camera or taken off the lens after first putting it on. It's been about 9 months since I had this camera. The zoom lens won't unlock after rotating it like I normally would. This has been going on for 2 months. What can I do to fix it so the lens will unlock and I can use the camera again?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 달기
답변 5개
가장 유용한 답변
I had this problem too. I took out the 3 outer screws on the back of the lens, one seemed loose, peeked in and decided there was no way I was going to fix this thing. Screwed it back on and the camera worked again. I suspect the screws were loose. Give that a try and see if it works.
I know I was about to throw my NX-mini out when I took the chance of unscrewing it. I wouldn't try to remove the back. Just try tightening the outer screws.
Update (10/27/2017)
Update: It stopped working again.
I had a technician at work take a look at it and he found that a ribbon cable in the lens sheared. He removed the cable and it works, kind of, in manual mode. I will be sending the lens to International Camera in Chicago to have it repaired.
이 답변이 도움이 되었나요?
점수 4
댓글 5개:
Thanks Man. You really helped me.
의
omg thank you so much this helped
의
Its a really answer, thanks a lot brother
의
Thank you! Great!
의
My case is "kinda". I have to dismantle the lens, tighten the inner ("second layer") screws, re-set the main cable (which seemed to be totally fine), and it works again. But tighten the outer three screws did not work.
의
댓글 달기
It works for me too. Just tighten the 3 outer screws, then on off once.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
You legend! Thank you!!! It worked. Might I add that I had to remove the three outer screws and put them back in before I was able to successfully fix it. So thank you for sharing your answer.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Well you should go to near camera repair or hardware repair shop and give to some one who have the proper knowledge of how to fix this type camera.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
If you break the flex print it also unlocks again. Mine was likely already damaged and broke completely off in the last steps of re-assemble. Don't see any drawbacks but haven't used the camera much in the last 4 years due to this constant issue ;)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
katiexyooj 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 43
전체 시간: 6,121
