주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Parrot SA에서 제조한 Parrot Hydrofoil Orak은 하늘과 바다에서 모두 즐길 수 있도록 비행이 가능하며 보트 섀시에 부착할 수 있는 이중 목적 미니 드론입니다.
Why won't my minidrone charge?
I've plugged in my minidrone to the power adapter but the LED that is supposed to indicate charging remains off. I recently had to remove the battery to replace it so I don't know if I reinstalled it incorrectly. Any help here would be much appreciated.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
가장 유용한 답변
Hi Jacob,
Sounds like a frustrating problem you're having! First off, you should make sure your battery is installed correctly. The triangle printed on the battery should be facing up and the battery should be inserted in the direction the arrow is pointing. If you battery is correctly installed, it may be an issue with the cable you're using to charge. Make sure that the charger has at least a 2.4 A rating and leave it charging for roughly 25 minutes. If the battery is correctly installed and the charger has the correct power rating, then you may need to replace your battery. I hope this helps, good luck!
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Jacob Munson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 18
전체 시간: 1,415
