주요 콘텐츠로 건너뛰기
The Roku 3 (Model: 4200) is a third generation streaming device released on March 5, 2013. Connect to any television or video display with correct input connections to stream available content.
Why is my Roku 3 not connecting to WiFi?
My Roku 3 is not connecting to the internet in my house.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 2개
My Roku 3 fell into water. It does not respond now so I can't use home and OK buttons. Is it fixable? I put it on my air vent to dry. No evidence a place to take off the cover. Is it fixable or is it cheaper to get new one? Only the controller doesn't work.
My roku will not work. Light just blinks.ipluged into all ports and nothing only a year old I want it replaced
댓글 달기
답변 5개
가장 유용한 답변
If your network is a private network, make sure that the network password is correct.
Try moving closer to the router or remove as many objects from the path of the router to the Roku.
For a more in-depth troubleshooting guide, visit the WiFi section of our troubleshooting page.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Open your Roku device and select the wifi connection setup. Enter the password of your home wifi to setup the wireless connection. There will be the indication of 3 green check marks to finish the setup. If it fail to get 3 green check marks, repeat the steps
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Try the following steps:
·        Connect your Roku box or stick to your TV and power ON.
·        In the very first screen, Choose ‘Wireless’ if you are going to connect via go.roku.com/wireless.
·        Roku will search for the network connection, select your network and finish the process till you select the option ‘Connect’.
·        After this step, your Roku will automatically show you the updated software.
·        ‘Download’ and install it to complete the '''Roku wireless setup''' process.
Hope, this will solve your issue.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Roku not connecting to WiFi !
hen trying to connect to the Wifi, the Roku device shows you a list of all available WiFi networks. You need to pick your network and then type in the password for your WiFi. However, sometimes the WiFi might not connect or Roku players that have been working fine in the past might start showing “Not Connected” on the home screen. These devices would then give you an error code when trying to connect to your wifi. So, if your Roku is not connecting to wifi, here is a list of all Network related Error Codes followed by best practices on how to resolve the Roku Error Codes and finally resolve roku not connecting to wifi issue.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
How do I go to the network it want let me go on the network it stops me we’re it us about
댓글 달기
for one why you charge 1.00 dollar to try to get your Roku fix I haven’t had know Enternet for 3 days now I am trying to figure out what is going could you help me please
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Isobelle Espiritu 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 22
전체 시간: 1,875
