주요 콘텐츠로 건너뛰기
모델 A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, 또는 2.4 GHz Core 2 Duo 프로세서
1203 질문 전체 보기
My screen has a speck on it?!?
So I generally keep my MacBook in very good shape, but the other day I noticed a little speck in the middle of the display. I ran my fingers gently over it and felt something (so it's not a drop of water or something). Between the keyboard and palm rest I also found a little piece of something, which I scraped off (this is approximately the same position as the speck on the screen). I don't want to scratch at my displya trying to get something off, for fear of damaging it. Is there some way that I can:
A) Determine whether I can safely "remove" this speck, and
B) If it is an indentation or other mark on my display, can I fix it without replacing the whole display?
All help is appreciated, and thanks in advance!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
Spray a little Windex on a very soft cloth and see if it will dissolve.
Update: If the speck bothers you that much, here's the guide for replacing the screen: MacBook Core 2 Duo LCD & Inverter A1181 (fast method) Replacement
해당 답변은 도움이 되었습니까?
점수 3
댓글 9개:
Thanks for the suggestion Mayer, however this did not resolve my problem (although I haven't cleaned my screen properly in a while, so it did make the screen cleaner overall). After a few minutes of rubbing at the spot, it is still there. Any other ideas? I think I remember hearing that Vaseline could be used to fill in nicks in this type of display, although I can't verify that it's a good idea or not.
I really wouldn't put something like vaseline on my screen as it would attract dirt. Try using a magnifying glass to see what it is.
It looks like it's a small indentation. It's darkening the pixels in about a 3x3 range, which makes it quite visible whenever I work. Any ideas?
Look on the keyboard to what's sticking up to high and causing the indentation.
There was a piece of something there before, I scraped it off already.
댓글 4개 더보기
댓글 달기
귀하의 답변을 추가하세요
Adam Hintz 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 8
전체 시간: 2,091
