주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fahrenheit FHT 125PRMR 헤어 스트레이트너는 두 개의 세라믹 플레이트 사이에서 열을 가해 머리카락을 펴는 기기입니다. 이 기기는 머리카락을 펴거나, 컬을 넣거나, 웨이브를 연출하는 데 사용할 수 있습니다.
Why is my fahrenheit flat iron not heating up?
One of the heating pads on my Fahrenheit Flat Iron is not heating up. I have plugged it in to several different outlets to make sure it wasn't the outlet that was causing the problem. How could I fix this problem without having to replace the whole unit?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 4개
선택된 해법
Hello,
Using one of those working outlets, please take notice of whether on not the green and red LEDs are light when the device is powered on. If the lights are on when the device is powered on then the issue likely lies with the internal cabling or the heating pad. If the lights are not turned on when the device is powered on then the issue is likely with the power cable or the motherboard.
Please use the following link to properly troubleshoot any of the above issues.
Fahrenheit FHT 125PRMR Troubleshooting
이 답변이 도움이 되었나요?
점수 2
댓글 달기
가장 유용한 답변
plug it up and plug it out then just do the  keep doing it about 5 times
이 답변이 도움이 되었나요?
점수 3
댓글 5개:
Omg thank you so much. My straightener would not heat up then I tried your method and it worked!
I'm have a similar problem when I plug it in and turn on the temperature continues to go to 022f it won't get hot at all does anyone have any advice please ...thank you
Hi i have a digital display for my temperature on a silver bullet fd200 and the temperature goes up but doesn't stay it goes back to 000°c. So i turn temperature up to 220°c then it flashes and goes back to 000°c. What could the problem be?
This worked on the third time 😍👏🏾 thank you so much. I probably didn't need to throw out my hot comb this method could of worked 🥴
My straightener will turn on. It’s digital , and it shows on the screen that my temp is going up and down. My only issue is that it won’t heat up. Sometimes when I plug it up, it’ll mysteriously heat up but most the time it doesn’t. What can I do?
댓글 달기
here are few steps which i was tried and got my straightener fixed you can also try these to fix yours
이 답변이 도움이 되었나요?
점수 0
댓글 달기
T3 Hair Straightener Not Heating UP.
Here a few possible solutions that you should try to fix your T3 straightener.
  1. factory reset straightener
  2. ensure the screen is locked
  3. and straightener plugged correctly into power source
  4. check your power source working correctly
here you can read more details to fix T3.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Joshua Potts 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 39
전체 시간: 41,245
