주요 콘텐츠로 건너뛰기
Sony 40” LCD TV Model KDL-40V5100.
1 질문 전체 보기
No Image on TV Sony Bravia KDL-40V5100
https://www.flickr.com/photos/truvor/302...
Our Sony Bravia KDL-40V5100 suddenly froze, hiccuped and stopped showing an image. Instead the display started showing vertical lines that look like an aurora borealis. Sony support told me that the panel is dead. We also thought that maybe replacing the t-con can fix this, but somehow it's doubtful. Sony tech on communities.sony.com suggested resetting something on the on-screen menu. I guess he missed the part where there is no menu and no longer a screen. In other words Sony was not helpful - neither the telephone support nor the techs trawling the communty boards. (Trolling may be apropos)
Update (10/26/2016)
So I got around to opening up the panel of the KDL 40V5100 and found that there is a heat sink covering the T-Con.
Update (10/31/2016)
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 22개
Any suggestions on opening the heatsink?
Looks like it is screwed down with some Phillips head screws. Tried to unscrew those to see what gives?
I'll do that. However, at this point, no one has a replacement T-Con board. The Samsung LJ94-02782B is out of stock on the reliable sites.
Take a look at the board with the heatsink removed and post some good images of it. There may be components that we can identify as the culprit. I noticed theere is at least one fuse on the T-con board
댓글 17개 더보기
댓글 달기
답변 1개
선택된 해법
@truvor does not look like a failed LCD. This does look like a failed T-con board. I'd definitely start with that. Of course, open the back and check for any loose cable are well as any obvious damage as well
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Thank you. I will investigate.
댓글 달기
답변을 추가하세요
Peter 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 19
전체 시간: 1,321
