주요 콘텐츠로 건너뛰기
LG G4는 늘 그렇듯이 고급 사양과 세련된 패션 감각을 강조하여 프리미엄 스마트폰 시장에서 눈에 띄는 제품으로 2015년 6월 초에 미국에서 출시되었습니다. 이동 통신사에서 판매하거나 잠금 해제 (미국 또는 국제) 된 휴대폰의 각 버전에 따라 모델 번호는 다릅니다. 일부 LG G4에 부팅 루프 문제가 있는 것으로 알려져 있습니다.
LG G4 screen turning itself on after timeout
This issue started about 3 or 4 days ago for the record. I have been trying to find a solution online but I have yet to come across a real solution (other than sending it in to LG for 9 days (completely unacceptable)). It happens whenever I turn the screen off, either through the lock button or the double tap. The screen will power off correctly and then turn itself back on within the next second. If i leave the screen to timeout at 15 sec like I have it set to, the phone will dim and then the screen will close, only for the screen to immediately turn itself right back on. This is killing my battery life and making my phone constantly overheat. If someone has found a solution please share it with me, I am reaching my wits end
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 5개
Hi, Did you update the phone or install any new apps just before the problem started?
No nothing no update no new apps but here is one thing when i plug it to charger the problem goes away
hi, It's beginning to sound like a battery problem. Just wondering if you charge the battery to 100%, remove the charger and see if it happens then or if it only happens when battery is at a lower %.
You may already be doing these things and it has nothing to do with your problem but every little bit helps. This link explains ways of extending the battery life. Hopefully it may be of interest,
http://www.gottabemobile.com/2016/02/15/...
Battery health is good i dont know where the main problem i guess the charger port i guess btw i use samsung charger
My phone just started doing this two days ago. i turn if off and then 2 mins later my screen turns on. I clean my "power button" with an alcohol wipe. Pushing it as I am cleaning it. It is not the battery as Its news. The more I am cleaning it, the less my phone turns on. Not saying this could be the problem but it helped me. My phone no longer turns on.
댓글 달기
답변 2개
선택된 해법
I had the same issue for quite a while ... I believe I found that it's the "Knock On" feature of the phone causing the problem. If the LG G4 is tapped twice while sleeping, it wakes. On the LG G3 that setting could be turned on/off, but on the LG G4, that setting is not made available.
I think that the accelerometer in the phone, or something in that Knock On feature that monitors the accelerometer, has gotten way too sensitive in one of the phone updates. Now that I've turned off that feature, my phone stays dark and quite, as it should after I put it to sleep.
There's an app in Play Store called QuickShortcutMaker that can be used to make a shortcut to the hidden Knock On setting. After installing, while looking at "Activities", type "Knock On" in search. Settings should show up in the list underneath. Select the down-arrow next to Settings, and a couple sub-settings will appear. They should be "Knock On" type settings and you can choose either one, they both do the same thing. Select one of them, then change the name from Settings to "Knock On" for the shortcut you're going to create, and you can choose a different Icon for it. At the bottom, create the short cut, then find it on your display and select it. Or just select the "Try" in the QuickShortcutMaker to open the Knock On setting and disable it.
Here's a link to where I found this information: https://www.phonearena.com/news/How-to-d...
LG G4, may you sleep long until needed.
Hope this helps!
BabbleBits
이 답변이 도움이 되었나요?
점수 2
댓글 달기
For anyone having this issue in the future, check that it’s not the screen (Or perhaps more spcifically, the digitizer.)
I had a similar issue after using this phone for many years, the LG G4 has a double tap to wake feature that you can’t turn off, at least not through normal means. There is an app you can use to launch a ‘shortcut’ that will let you disable it. After doing that, my phone no longer woke itself up. Never fixed the actual issue, as I upgraded phones not long after, but I’d guess it was the digitizer that causes this.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
ilyass bouzid 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 29
전체 시간: 8,905
