주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 5.5” 스크린 iPhone은 iPhone 6의 큰 버전입니다.
1525 질문 전체 보기
phone internal speaker not working after battery change
I swapped out the battery in my iphone 6 plus. I inadvertently removed the 2 screws at the top of the battery and disconnected those connections prior to removing the correct battery connections. I replaced the connections and bar across the top. I replaced the battery without incident.
The phone booted right up but i have the following conditions:
1) people can hear me during a phone call but I cant hear them, unless I place them on speaker phone.
2) people cant see me during facetime, though i tested both cameras and they seem to work fine.
I believe something got disconnected while I had the display open but I thought I would try this forum before taking the phone apart and putting it back together. Any ideas what might be disconnected still?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Sounds like it could be a tear in the front camera flex cable. Its extremely common since its very delicate and easy to damage. Disconnect the battery, then disconnect the display assembly. Clean all the connections and make sure all the cable are seated properly. If the issue persists, its an easy fix.
iPhone 6 Plus 전면 카메라 및 센서 어셈블리 교체
iPhone 6 Plus Front Camera and Sensor Cable
iPhone 6 Plus Front Camera and Sensor Cable 이미지
상품
$9.99
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Jack 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 1,922
