소개
이 안내서를 사용하여 전면 카메라 및 센서 어셈블리를 교체하세요.
분해를 시작하기 전에 iPhone 전원을 끄세요.
Lightning 커넥터 옆에 위치한 3.6mm-길이 P2 Pentalobe/펜타로브/별나사 두 개를 풀어주세요.
플라스틱 깊이 게이지가 iSclack 중앙에 부착되어 있다면 지금 분리하세요—iPhone 6 Plus 처럼 대형 휴대폰에는 필요없습니다.
iSclack 핸들을 닫아서, 흡입컵 턱을 여세요.
iPhone 하단을 흡입 컵 사이에 놓으세요.
손잡이를 열어서 iSclack 턱을 닫으세요. 흡입 컵을 중앙에 맞추고 iPhone 상단과 하단에 단단히 누르세요.
기기를 다시 조립하려면 위의 단계를 역순으로 따르세요.
다른 119명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
100%
Christian Kim님은 저희가 세상을 수리하는데 동참하신 분입니다! 기여하시겠습니까?
번역 시작하기 ›
댓글 12개
My front microphone had completely stopped working exactly a week out of warranty. I replaced the front assembly with a new one from Fixit and afterwards it still did not work. Then I realized the microphone did pick up very soft sound if I shouted directly into it. I eventually repeated the entire disassembly and found a very thin yellow film glued to the microphone grill which had been muffling 97% of the sound. After peeling this off my microphone is working perfectly! I did not notice this on the microphone the first time and assume it was the backing for the self adhesive. Make sure you remove this - it is not obvious to spot!
Fantastic instructions! fixed my problem first time. Just be patient and try not to touch anything to roughly. Thanks for the tip from a previous comment saying to remove the yellow piece of film over the microphone. This saved me a lot of hassle. Thanks
Glad to have siri, dictation, sound in videos and hansfree calls back :)
Is the picture quality the same
