메인 콘텐츠로 스킵하기
모델 M6497 또는 A1005 / 500, 600, 700, 800, 또는 900 MHz G3 processor
167 질문 전체 보기
Can I put a logic board from a G3 12" 800 in a G3 14" 800?
I have a G3 14" 800 with a logic board that got fried around the power supply area. I also have a G3 12" 800 with a good logic board. Can I use the 12" board in the 14" case, or is there a problem with the battery connectors?
Also will it drive a 14" screen, or will it only use 12 size area?
답변되었습니다! View the answer 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
의견 추가하세요
아이폰 배터리 수리 키트
Only $29.99
Buy Now
아이폰 배터리 수리 키트
Only $29.99
Buy Now
4개의 답변
선택된 해법
You can! It's got the exact same form factor (the 14" uses a battery cable extension to get around the case size), and it will drive a 14" screen just fine (same resolution, bigger screen).
해당 답변은 도움이 되었습니까?
점수 2
의견 추가하세요
As far as I am aware, other than the difficulty of lining up the ports and battery connector, it's possible.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
Someone who knows how to handle a solder iron could take off the battery connector from the 12" board and fix it to the 14" logic board.
해당 답변은 도움이 되었습니까?
점수 1
의견 추가하세요
Thanks guys for your answers. Looks a rather complicated job (with 2 iBooks to take apart!) but the step by step instructions on ifixit are great. I'll do it over the next few days as the Christmas food wears off! Merry Christmas to all.
해당 답변은 도움이 되었습니까?
점수 0
의견 추가하세요
귀하의 답변을 추가하십시오
noel2 가/이 대단히 고마워 할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 1,230
