주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Pandigital Novel e-리더는 책을 읽고 웹을 탐색하며 오디오를 감상하기 위한 태블릿입니다. 모델 번호: PRD07T10WWH7.
Why won't my device start up?
Hi,
I recently got my device and it's been working fine but last night I tried installing an SD card and after telling me to please wait it turned off and won't start back up, any ideas on how to fix it?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
This could be caused by a few different things. Make sure the device has enough charge to power on. If the device is charged and the issue still persists, it could be a faulty power switch. This can be fixed by replacing the power switch.
Another cause could be the battery. The capacity of the battery is reduced after each charge cycle. This is a fairly old device and it is possible that the battery is no longer functional. You may need to replace the battery.
Finally, this issue could just be a result of the display not turning on. If this is the case, you will need to replace the device's display.
Pandigital Novel PRD07T10WWH7 Troubleshooting
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
what if when you try to charge it, it automaticly turns on? also has the same problem after it auto turns on
댓글 달기
I'm having somewhat of the same problem, like the other person said, probably something to do with the sd card, shot in the dark here, but try taking it out and letting the battery die, might just work
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Aaron Jesus 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 20
전체 시간: 1,852
