주요 콘텐츠로 건너뛰기
The G3 Controller is gamestop's version of a gamecube controller, equipped with A, X, Y, Z, B, Turbo Button, joystick, C-stick, left and right triggers, and a directional pad.
Why is my controller not being recognized when I plugged it in?
I plug my controller in but the console does not recognize that it is connected.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
I simply unhooked the controller, blew into the connector then plugged it in again and it worked.
댓글 달기
답변 2개
이 답변이 도움이 되었나요?
점수 0
댓글 달기
The Gamecube may not recognize your controller because of a faulty connection with the cube and the wire. As mentioned above, blowing into the connection piece of the controller may alleviate your problems; however this will probably only be temporary. Have you tried to connect the controller to different ports? If it doesn't work in any port, the problem is with your controller wire. If it does work in the other ports, the problem is you have a faulty port, in which case I recommend you check out gamecube repair guides. If it is a faulty cable you may want to invest in a new controller.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Andrew Gonsalves 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 271
