Why will the A button not work when I press it?
I press the A button in a game that uses it and it will not work. How can I fix this?
좋은 질문입니까?
좋은 질문입니까?
It's possible that there is something lodged beneath the button that is causing these problems. Opening up the controller and cleaning beneath the problematic button may solve this issue.
이 답변이 도움이 되었나요?
The button was dirty underneath so I removed it, cleaned it with rubbing alcohol and repaired it.
이 답변이 도움이 되었나요?
The A button may not work because the connection from the A button to the motherboard may be interrupted. I suggest you check out our button replacement guide.
이 답변이 도움이 되었나요?
지난 24시간: 2
지난 7일: 10
지난 30일: 17
전체 시간: 326
댓글 1개
Andrew Gonsalves 의
