주요 콘텐츠로 건너뛰기
모델 A1237 또는 A1304 / 1.6, 1.8, 1.86, 또는 2.13 GHz Core 2 Duo 프로세서
312 질문 전체 보기
keyboard and trackpad not working
This was my first macbook air. I like it a lot, but I rarely use it. Well, I have a lot of computers at my house.
Since last year that I purchased the newer macbook air with the ssd, this was not doing anything much.Now this year with the ipad, even less.
However something strange happened to this macbook air when I took it out and try to sell it on ebay.
Let me explain. When I power on the laptop, right away, I hear the familiar apple boot sound. Then the laptop continue to boot. And finally
when it finish boot, I try to use it, the trackpad does not respond, so is the keyboard. I was thinking it may had crashed. But when I press
the power button. The shutting down message appear. So I know the computer did not crashed. I plug in a usb mouse and it worked. After
I turn it off and on a couple times. The keyboard and trackpad came back to life again. Then I put up the laptop. But the next day when
I tried it again. Samething happened. But eventually they work again.
Here is what I find out. If the trackpad or keyboard don't work, they don't work at the same time, never alone and since they are both usb,
they don't show up in system profiler. I tried press shift+control+option+power, the laptop turns off. So the keyboard maybe working.
I tried reinstall the system fresh, same thing. I will say one of 20 tried, the keyboard and trackpad will work. Maybe more, not too sure.
When it work, they appear in system profiler.
 any boady knows wich is the problem in my mac
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 3개
선택된 답변
Well I've just had the same problem with a MBA late 2008.
The keyboard and trackpad wouldn't work at all - not even at boot time.
The USB port wasn't working either - it wouldn't boot from an external DVD drive.
I checked all the cables, looked for damage/spillage too - nothing.
Then I noticed that the late 2008 model has an nVidia 9400 chip in it. Could the USB ports/keyboard/trackpad be driven from the nVidia chip? I checked out the hardware description on the web and found that it does indeed drive the graphics as well as the USB, SATA, etc.
Knowing the nVidia chips around this era had issues with dry joints, I thought a reflow may be my last chance. So, out with the reflow station, let it cool and put it back together.
Powered on the MBA and the external DVD drive fires up, the keyboard and trackpad work too.
So, if you have the same problems, a reflow of the nVidia chip may fix it once you've tried the cables, etc first. I believe there are many services on the web that offer reflows on these chips.
Thought I'd share this with everyone!
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
가장 유용한 답변
From lack of use the connections may have built up some resistance on the connections for the keyboard and trackpad. Open up the computer and clean and remake the connections. If this doesn't work let us know and we will look further.
MacBook Air Models A1237 and A1304 Trackpad Control Cable Replacement
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
I'm having this exact same problem. I have replaced the trackpad control cable and the top case... I fear that it is a bad logic board..
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
jaime ruiz 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 2
전체 시간: 13,461
