주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon ELPH Z3 모델 카메라는 2012년 3월 미국에서 출시되었습니다.
Why doesn't my camera's flash work?
I was trying to take a picture of something that is in a dark background so I tried to use the flash feature on my camera. However, despite adjusting the setting to "flash on" the camera failed to produce a flash for the picture. What may be causing this issue?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Student question
의 공유
댓글 달기
답변 1개
선택된 해법
This issue is quite common in some cameras and the solutions can range from simple to pretty complex. Sometimes the reason a camera's flash will not work is because the battery is already running low to the point where the camera can no longer produce a flash. To resolve this all you would need to do is replace the batteries. If that is not the case and your flash is still not working, then there may be a defective flash circuit in which you will need to plan out an exchange with the company you have purchased the camera if it is still under warranty. Hope this helps!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Nathan Barros 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 21
전체 시간: 552
