주요 콘텐츠로 건너뛰기
Device and repair information for the Behringer Eurolive B212D speaker system.
31 질문 전체 보기
Why does my behringer b212d cuts off when playing?
My behringer b212d music cuts off when playing and the volume is set around 1/2 to 2/3? The next day it comes back on. I notice if the volume is set real low the music does not cut off for a long time. I DJ, so I need the speaker to work like it was designed to do.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
My Beringer speaker keeps going low to high. How do I fix it. I already changed the fuse
I am experiencing this when I am playing a guitar and vocals through into the mixer. Suddenly my microphone went quiet then didn't have any output at all. I changed the cable and it was louder again. Then on another occasion the same thing happened again. This is a fairly new power amp but the speakers are old. Could it be that the speakers need replaced?
댓글 달기
답변 1개
선택된 답변
@jeffburt27 sounds like bad amplifier IC's. Use these guides to disassemble your amp and take a look at the circuit boards. Check the IC's for obvious damage. Post a couple of images of what you see with your question. For that use this guide. That way we can see what you see.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
Jeff 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 15
전체 시간: 1,315
