주요 콘텐츠로 건너뛰기
This is a, 35.70 cm (L) x 25.70 cm (W) x 2.54 cm (min H) / 3.96 cm (max H), notebook PC the unit weighs 6.6 lbs. It was released in 2006 and comes standard with a 80 GB hard drive.
Why do I struggle to connect ot WiFi?
My notebook struggles with Wifi connection. If it is connected the signal is always weak. I can be right next to a laptop that has full Wifi strength and I can't connect at all. Sometimes the signal goes in and out, when there is no change with the router or even if I stay in a stationary position.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
You may or may not have a broken or faulty WiFi card, or the antenna may be disconnected.
Here is a link to our repair page.
HP Compaq Presario V6000
이 답변이 도움이 되었나요?
점수 0
댓글 달기
You can try disconnecting and re-connecting the WiFi Card on your laptop's motherboard.
Another thing to do is:
Go into Device Management (type devmgmt.msc in Run window) -> Double click on Network Adapters ->
Uninstall the 802.11 g/b driver (uncheck the option that asks if you want to remove it from your system) then click the top-right most icon that says Scan for Hardware Changes.
Now try connecting to your network.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
PJ Andress 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 6
전체 시간: 366
