주요 콘텐츠로 건너뛰기
Pilot not holding Goes out after let go the button.
Hello... trouble with the water heater.
First the pilot wouldn't lite.. so i turned it off for 10min to clear the gas and tried
it again and the pilot worked. I hold the pilot button down until the status flashes but
the pilot goes out when i let go the button. I was told there is a reset button so i pushed what i thought was the reset but it doesn't push or click. Any thoughts?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
Tested the Thermopile and the mV reaches above 500 mV and continues to go up after about a minute of holding down the pilot button, but as soon as you let it go it drops back down to almost nothing.
댓글 달기
답변 1개
선택된 답변
@cameraparts4you , Be extremelly careful working with your gas appliance, if unsure contact a Qualified Technician. Dirty TC( thermocouple), faulty TC, pilot flame to not set properly/small or not close enough to TC, partially plugged pilot tube, faulty/bad gas control valve, all could cause pilot not to stay lit. Check the attached links troubleshooting,instruction, Good luck.
http://www.doityourself.com/stry/reasons...
http://www.home-repair-central.com/gas-h...
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
귀하의 답변을 추가하세요
Sales Cameraparts4you 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 17
30일 전: 89
전체 시간: 23,733
