주요 콘텐츠로 건너뛰기
The Chevrolet Cavalier is a compact automobile produced from 1982 to 2005 by General Motors.
139 질문 전체 보기
Why does it pull to one side when brakes applied?
The car hase been to several repair shops and everything to do with the brakes have been replaced. Calipers, hoses, rotors, pads, and even one shop replaced the lower arm bushings. No one can figure it out!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
가장 유용한 답변
If it's
been in an accident it could be a bent frame, or alignement (photo looks as if passenger side has been dented) it could be the power steering pump has a blocked port or crimped hose.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
That's the iFixit photo for the device page, not this person's exact car. Good eye, though.
Thanks and no its not been wrecked and that photo is not it. Car ran straight and true for years and then it just started the pull. Seems if you jab the brakes it pulls hard at first and then comes out of the pull as the braking is continued. I am leaning toward a bad master cyl or ABS unit maybe.
댓글 달기
귀하의 답변을 추가하세요
mark 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 994
