주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Why does it pull to one side when brakes applied?
The car hase been to several repair shops and everything to do with the brakes have been replaced. Calipers, hoses, rotors, pads, and even one shop replaced the lower arm bushings. No one can figure it out!
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 1개
가장 유용한 답변
If it's
been in an accident it could be a bent frame, or alignement (photo looks as if passenger side has been dented) it could be the power steering pump has a blocked port or crimped hose.
Remember to return and mark accepted the answer that best solves your problem.
Good luck,
N
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
That's the iFixit photo for the device page, not this person's exact car. Good eye, though.
Thanks and no its not been wrecked and that photo is not it. Car ran straight and true for years and then it just started the pull. Seems if you jab the brakes it pulls hard at first and then comes out of the pull as the braking is continued. I am leaning toward a bad master cyl or ABS unit maybe.
@mark35955 try flushing brake lines they might have trash in it or pinch in like or one caliber is sticking
댓글 달기
답변을 추가하세요
mark 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 27
전체 시간: 1,183
