주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1687/A1634. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
1041 질문 전체 보기
restore not working iPhone
Hi all,
my iPhone suddenly decide not work, I went to apple store they can replace it but not fix it. they recommend to me a repair store which cost me 1000$.
anyway can help to backup at least the photos,,,please
abounded thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 9개
선택된 답변
Please take these steps and post your results. It will help us narrow down the problem:
1. Connect your phone to your computer. Does your computer see it?
2. With your phone connected to your computer, hold down the power button for 5 seconds. While still holding power, press and hold the home button for 15 seconds. Once the Apple logo appears, release the power button while still holding the home button. Does iTunes see the phone now? Does the display work now?
The answers to those questions will help us a lot.
해당 답변은 도움이 되었습니까?
점수 3
댓글 7개:
Hi,
1. when the phone connected the computer cant see it.
2. nothing happened at all. the screen is black.
thanks
OK...that tells me that the phone has some issues. Its not powering up at all, even on the charger. So there are a few things that could be wrong. The Lightning port is a possibility. Could also be a bad battery. Neither of those are likely, they are possible though. More likely is the logic board of the phone suffered damage by getting wet, getting dropped or by using non-MFI certified chargers and cables.
You could through a new Lightning port and battery on it to make sure, but it does not sound good.
Josh made excellent troubleshooting recommendations. Without knowing the history of your phone prior to failure, it is impossible to diagnose. If you can, please tell us more about what happened to your phone.
If you don't have the experience or the tools necessary, you should consult with a qualified repair shop that does micro soldering for a proper repair or data recovery.
I feel kind of bad because with Apple phones, the answer is usually "Your board is fried and it needs expensive repairs that maybe 15 people in the entire country can do".
Sucks
thank you all for cooperation,
I think doing ethier
1- changing the battery
2- putting the logic board in other iPhone
but the question, am I going to loss the data?
댓글 2개 더보기
댓글 달기
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
Data will not be lost when trying the logic board in another housing. I doubt it would help at all because the logic board is basically the whole phone.
Changing the battery will not cause the data to be lost as well.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Hi,
thanks
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Sucks
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
as Ben The Great said, neither of those will cause loss of data. They are both very good ideas.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
I like the title "Ben The Great" ;-)
I think it should be official @mayer
댓글 달기
hey
I have had the same problem with my phone.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Sabir 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 252
