주요 콘텐츠로 건너뛰기
Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
299 질문 전체 보기
Why dont my reverse lights work when I put it in reverse?
My reverse lights havent worked since i changed steering columns. So that i had tilt the other day i plugged in a trailer and they suddenly started working since i dont know where their activated from its hard to track down the problem
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 답변
Trikkidick West, since the reverse lights went out after changing column probable bad wire/plug connection at the park,neutral,reverse bulb switch which is attached to lower part of steering column. Strange thing is you say they are working now after plugging in trailer plug so you should also follow that harness and check for shorted/damaged wires, also make sure all grounds are clean and tight. Link below shows a diagram of switch on column, switch is #3 on diagram. Good luck.
http://www.truckforum.org/threads/backup...
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
귀하의 답변을 추가하세요
Trikkidick West 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 10
전체 시간: 811
