주요 콘텐츠로 건너뛰기
Samsung에서 제조한 Samsung Galaxy Note 5는 (Note5로 불림) 스타일러스를 탑재한 phablet/패블릿 스타일 휴대폰입니다, 2015년 8월 출시.
271 질문 전체 보기
Icons All Messed up
I downloaded am emojii launcher app, and deleted it, but it has really screwed up my phone. When I swipe to open phone it asked me what launcher I wanted to use to open with I had to choose one in order to open phone. Now all my icons are large and all over the place, plus there are blank icons as well. How can I fix this....please help.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
You had the other launcher set as default. When you uninstalled it, it lost that default so it makes sense that you had to select the default home launcher after you uninstalled it.
As for the icons, a launcher does a lot of things and the app drawer, home screens, widgets and icons are all tied to that launcher. Uninstalling it means you need to set things up again for the default launcher.
Are the blank icons in your app drawer or on a home screen? If they are on the home screen, delete them and re-add them. If you had widgets, its very common for those to end up as blank icons after deleting a launcher. The big icons aren't something I have seen, but if they were on a home screen, changing the launcher could mess them up. Try deleting and re-adding them to the home screen and see if that fixes it.
If these problems are in your app drawer, go to:
Settings > applications > application manager > more > show system apps > touchwiz home > force stop > storage > clear data
Hit the home button. It will probably have you set Touchwiz Home as default again. That should fix any weird icons.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Go to:
Settings > applications > application manager > show system apps > touchwix home > force stop > memory > clear data.
Hit home, you will probably have to select touchwiz home as default again.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
bafone 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 2,659
