주요 콘텐츠로 건너뛰기
Sony M-430 Microcassette-Corder can record and play back audio. The one-touch recording and two-speed record/playback and automatic shut-off makes this ideal for on the go recording. Model number M430.
9 질문 전체 보기
Drive belt replacement, replacement parts
Where can I obtain a replacement drive belt for this unit?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
@cestrangio , Christopher use the links below, 1st link is Sony parts page where you could inquire about availability and the other links are belt suppliers that may have a suitable replacement for your M430. Good luck.
https://esupport.sony.com/US/p/model-acc...
http://www.thevoiceofmusic.com/catalog/t...
https://www.kenselectronics.com/lists/be...
http://www.gbaudio.co.uk/data/belts2.htm
해당 답변은 도움이 되었습니까?
점수 3
댓글 4개:
@lpfaff1 Wow I'm impressed you were able to find anything on something so old . Nicely done
@jimfixer , thanks Jim, and what about you where did you find that B code, I thought they only went up to B3000, good job on that one.
Hi @jimfixer and @lpfaff1
If ever you need belts here is one good resource for most belts. Although would you believe the one being asked about wasn't there!
http://www.russellind.com/client/downloa...
@cestrangio and just in case you need it, the Sony part number for the belt is 3-377-420-11
댓글 달기
귀하의 답변을 추가하세요
Christopher Strangio 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 26
전체 시간: 2,800
