주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Released January 2015. Android smartphone.
Phone doesn't charge anymore
My phone is the redmi 2s prime edition and recently when i plugged it into the charger to charge overnight, i found out that in the morning that it doesn't charge anymore and the phone has switched off as well.
So when i plugged another cable to the charger and tried to charge it, it still doesn't work, and then tried another charger from my older phone but it still doesn't work.
So i tried plugging in the original cable which i used it to charge the phone overnight to my laptop and i found that it has some power error because once i plugged it in, windows gave me an error about a power surge which had never happent before.
Then i tried another traditional (Classic) way of charging the phone battery by using an old USB cable and then using the ends of the positive and negative cables i plugged them into the battery and that gave it around 5% of charge by which i managed to start up the phone.
So does this mean that the USB Charging port of the phone is burnt ?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
Possibility of the USB charging port on your phone to simply get spoiled, it's a common issue, just change the port and you should be good to go.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
So i checked online and found that there is a separate module for the charging port, i think ill buy that and replace it with that
댓글 달기
답변을 추가하세요
Kanishka P 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 30
전체 시간: 489
