주요 콘텐츠로 건너뛰기
A Windows phone known for its camera capabilities. Also known as Nokia EOS, Nokia 909, Nokia RM-875, Nokia RM-877, Nokia RM-876.
42 질문 전체 보기
My lumia died help me please
I have a problem in my lumia 1020. My little sister threw it in the floor and it died . It never work . I tried to turn on the phone but , I don't get a response. When I charge it light shows from the start button
And disappear after few seconds.
What do I have to do?
If I need to change components, what are their names? Can I buy them from the Internet ?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
@mohannadfatani before thinking about replacing parts, you need to find out which once. There are no standard parts that fail when the phone gets dropped. Start by opening up the phone and check the battery. Check to make sure it is seated, charged and the contacts are properly aligned. If they are then you need to dig deeper. Follow this video to disassemble your phone. Check for dislodged cables, broken components, check that the power switch is okay etc. You will need to invest in a multimeter etc. to do any further testing.Take plenty of pictures of the motherboard etc. and post those with your question. That will allow us to see what you see and possibly help you figure it out. Use this guide for that.
해당 답변은 도움이 되었습니까?
점수 3
댓글 3개:
I opened up the phone and checked the battery but I didn't open the battery. Should I ? If I open the battery , does this will affect on the performance ?
I returned the parts and I got the same problem .
@oldturkey03
@mohannadfatani not sure what you mean by opening the battery. Just remove it from the phone and take a look at the contacts from the battery to the phone.
I did what you said . Unfortunately nothing happened. @oldturkey03
댓글 달기
귀하의 답변을 추가하세요
Mohannad Fatani 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 4
전체 시간: 263
