주요 콘텐츠로 건너뛰기
재봉틀 수리 및 분해에 대한 정보는 다음 안내서를 참조하십시오.
92 질문 전체 보기
Skips threading in between sewing.
Hey everyone!
So heres a good question. Does anyone know why a commercial grade juki sewing machine would be skipping stitches while sewing? I work at a location where this happens a lot and we have to outsource the labor for repairs. However it would be beneficial for the company to have someone there to fix this issue. Please let me know as far as what could be the issue and maybe how to go about this maybe? I do appreciate all of you guys and thank you for your help!
-Daveyloder
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
It could be any of a number of issues:
  • thread/needle incompatibility
  • incorrect top/bottom thread tensions
  • blunt, worn or damaged hook
  • timing slightly out
* etc.
You will need to work through all possibilities, one by one, and, if still a problem then ask a Juki engineer to look at it,
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
If it is used commercially, then it will accumulate a lot of debris quickly. That can prevent the rotating thread pickup under the plate from grabbing the thread and a missed stich occurs. On the other hand, your outsourced labor needs to eat also, so why deprive them?
댓글 달기
귀하의 답변을 추가하세요
David Loder 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 4
30일 전: 5
전체 시간: 70
