주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
Touch only working on second try
A customer brought me an iPhone 5, the problem is that always when the screen is off for a longer time (at least 10 minutes) and I turn it on again, the touchscreen isn't working right. When I turn the screen off and on again it works fine. What could be the problem? Already tried reconnecting the flex cables. Could the display be faulty?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
You could have a bad screen assembly. The logical first step is to replace it with a good quality part.
The iPhone 6 and 6+ are well known to have problems with Touch (Touch Disease) but this is not a common problem with the 5.
iPhone 5 Screen 이미지
상품
iPhone 5 Screen
$34.99
해당 답변은 도움이 되었습니까?
점수 4
댓글 2개:
Yep you nailed it.
I noticed an increase in temperamental behaviours with touch on a couple iPhone5 after updating to ios 10. Might be a coincidence, but...
댓글 달기
there is a prossesor that starts to loose its conections due to the phone being subjected to bending.this prossesor is responsible for touch recognition.ifixit can show you wich one it is so you can replace it if it is economical to do so.There is no guarantee this is the issue but i would put money on it.good luck and always have fun fixing.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
ppalfinger 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 4
전체 시간: 80
